Fulltimeme2ExplorerAug 06, 2019AC issues,Hello! I have a 2003 komfort 5th wheel, I am a fulltimes in it! My issue is my AC unit makes a clicking noise and at times cycles on for a bit, then off,,, even when the wall thermostat switch is in ...Show More
Wild_Bill_888ExplorerAug 06, 2019Disconnect thermostat at the unit, clicking should stop. Jumper ac thermostat input, unit should run continuously.If so Chris is probably right. If not the problem is in the ac or its power supply.
Related ContentTowing lights issueSuper frustrating AC issue12 Volt Power IssueElectrical outlet issuesDometic AC Issues
