We have a Dometic A/C that's stalling out. It stalls anywhere from 1-5 seconds then comes back on. Sometimes it comes back on blowing stronger than it did before it stalled. Anyone have this proble...
Maybe a controller problem but ??? someone more knowledgeable than me might be able to chime in.
As far as air leakage you will have to take the filter cover off and check the seal between the two sides. It is fairly obvious when you look up in there.
