Perry42985 wrote:
The FW is wired for 50A. The existing unit is old and on its last leg so I and to replace it as well. Would the additional unit typically run into the ducting system?
If you remove the interior frame for the bedroom vent, you will probably see the end of the duct for the second A/C, there should also be 120V ac wire and small gauge wire to connect to the thermostat. At least that was how mine was. But I also discovered that rather than ducting out both sides, there was only one. And since there were only 5 vents total, I was concerned that two units would just have too much air flow for limited ducting and vents. So, while I could have installed a ducted 2nd A/C, I instead opted for a non-ducted unit that is still controlled by the multi-zone thermostat. So, you might do a little more investigating before actually purchasing any specific unit.
Generally, the best prices are on 13.5k btu units and while a 9k unit may be sufficient for the bedroom, the 9k may actually cost more, have a worse SEER number and therefore use the same amount of power. Also, you might consider height of the 2nd A/C and it's impact on max trailer height. Anyway, I went with a low profile 13.5k unit that only added 3 inches in trailer height compared to the top of the bathroom skylight.
