Old-Biscuit
Jul 14, 2015Explorer III
ALL movement/pivoting is done at turret.
Wedge stops any movement at king pin.
Wedge MUST be properly adjusted for hitch being used
When hitching up wedge bolts are loose.then wedge is tapped as far forward as it will go then bolts tightened (150 #/ft torque)
Wedge goes on differently depending on which hitch.
That wedge needs adjustment or it is not flipped the correct way for that particular hitch
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 20, 2026
