djousma wrote:
laknox wrote:
djousma wrote:
My opinion, stick with hydraulic. More than enough power to autolevel front to back, and side to side, and the controller make them all operate in sync, IOW, if it calls to level side to side, all 3 jacks on that side operate together. What you describe would torque the frame if not all operating in unison.
As for electric jacks, my buddy had them on his prior 5th. They didnt have enough lift capacity to level, only to stabilize.
It is odd to me, that a RV builder wouldnt go to 6 point hydraulic leveling if they already had front hydraulic jacks and presumably hydraulic slides as well.
Might check out lippert's system.
That's because your buddy had electric =stabilizers=, not electric =jacks=. Basically, he had what amounts to the old scissor jacks, but with an electric motor on them to save cranking them down. Electric jacks, OTOH, are true jacks, with plenty of lifting power. My 10.5GVW KZ can be lifted completely off the ground with the 4 jacks of the 4-point leveling system.
Lyle
Lyle,
It was the lippert 3.0 ground control 4 point leveling system. IOW, the front legs, plus 2 additional behind the wheels. And I know what lippert publishes (20K capacity), but for whatever reason on his KZ Durango Gold(weighed in at about 16K) they just were not up to the task.
$3500 for GC 3.0 6-point vs about $6000 for 6-point hydraulic. Quite a price to pay after the fact.
That's the same system I have. Frankly, your buddy should have complained to his dealer and KZ about it while under warranty. Likely the wrong capacity jacks were installed at the factory. I'd certainly check what the capacity of them are and replace them with larger jacks. Pretty simple; 4 or 6 bolts on each jack and 2 wires. Frankly, I'm surprised a Gold had only a 4 point system on it and not 6.
Lyle
