Protector's avatar
Protector
Adding 2nd awning on Voltage 3200 over rear entry door
Hello folks,
I am kicking myself for not doing this when we ordered our Voltage 3200, and now I want to add one, so I found retailer that sells the 10 foot awning for Keystonen and they contacted Keystone/ Dutchman customer service to see if in deed I could add the awning and I did not get a Yes or No they said this" I would advise against adding the awning unless you are sure there is proper backing behind the wall. This is the customers unit and this can be modified and added, but keep in mind that the project will no be simple because you will want to get visual confirmation of backing before securing an awning to it."
I am capable of installing the awning, getting power to it, what I am not sure of if there enough backing has anyone had any experience adding an awning??
I tried a stud finder looking for studs or some sort backing supports had no luck. Thinking about finding someone with thermal imager. any suggestions or advice
  • Yes side entry door, That was my thought finding someone with a thermal imaging camera. You would think that the mfg. could look at some drawings and tell you yes or no there is structural support but I guess it is not that simple??
  • Your talking side entry door not rear ramp door right.
    My thought is the structure should be there if it was a factory option. They only build 1 wall. They dont build a wall for the awning and a wall without the awning. Findin what structural memebers are in the area needed are easy via thermal imaging or even condensation in cool mornings.
    The bugger is the electrical
