Trail-Mate
Jul 02, 2013Explorer
A portable unit may work depending on your space. You might be able to build in a small window unit depending on if you have a cabinet you want to give up space in and a way to vent hot air out and drain. Did this mod years ago in a popup, Installed under dinette, flush with the front, Cut whole in camper side and installed a metal hinged refer vent on the out side, then used sheet metal to seal it to vent out the hot air thru new vent, whole was made in the floor for the drain.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
