outnaboutExplorerDec 20, 2014adding a heat stripI have a 2013 Montana and I want to install a heat strip in the AC. Can this be done and does anyone know if it might be pre-wired to the thermostat
rv2goExplorer IIDec 20, 2014I had a heat strip in the air conditioner of a previous RV. I really did not like it. Too much air flow for the amount of heat. I found that a small 1500watt portable heater worked much better. Newer units may be better.
Related ContentAdding Heat StripsAdding power outlets in slide with no wiringChanging heat pump to heat stripHeat stripDometic Heat Strip DMR702
