nguyenbio's avatar
nguyenbio
Adding a rear hitch...
I have a Grand Design 303rls towed by a 2015 F350 FX4 CCLB SRW. I am way under weight on all numbers and am wanting to add a rear hitch to the fiver to pull a utility trailer with my SXS on it. I will be under length and weight with double towing. I know the laws and regs since I am a LEO officer here.
My question is for those who have added the hitch. Experiences, problems, warning, successes, advice in terms of adding the hitch and towing concerns?
Thank you in advance for sharing!
    For towing, even a light trailer, you really need to have a sub-frame built for the hitch to support both the tongue as well as the pull.
    Lyle
  • I had a hitch custom fabricated on my 5er. Lighter trailers are fine but I am done towing my ski boat.
    If you have much tongue weight it really degrades the ride in your tow vehicle.
  • My FW has a factory receiver hitch. It is only rated for 300#s hitch wt. It is a very solid hitch, using square tubing across to the frame. I am thinking the low rating, is due to not wanting any more weight hanging on the rear.
    I have double towed with my last 2 FWs, with good results. It is a little more stress, that would get old, if you did it all the time.
    Jerry
  • Look at your maximum length restrictions. Some states are 65' nose to tail, some are higher or lower.
    Ken
  • Let me add that we will be traveling to only western states that allow double towing like California.
