1L243
Jun 18, 2017Explorer II
Is your rig 50amp? If so check the panel and see if there is a breaker marked 2nd AC.
You may be able to add a 2nd AC on a 30amp system but you will not be able to run both AC's at the same time. Running two AC's at the same time on a 30amp system would overload your electrical system... Adding a second AC when not prewired would be a RPITA!
About Fifth Wheel Group
