sin_cal_hd
Jun 18, 2017Explorer
1L243 wrote:sin cal hd wrote:
We have 50 amp. I doubt the rv is pre-wired for 2nd or even a 3rd a/c. I differently want a 2nd in the garage and put a vent fan in the bunk house.
Don't assume.. The only reason for 50 amp is for a second AC. Check the breaker panel for a breaker marked 2nd AC. Remove the inside vent moldings in the garage and bedroom to see if there is a prewired electrical box there.
If your not prewired and since you have 50amp adding a non ducted AC to the Garage vent would be easy if you have access to run wire to the breaker box..
I don't have a vent in garage at all.
Running wire to the panel is the biggest issue I see. Plus cutting a whole in the roof of the garage.
About Fifth Wheel Group
