slotsavegasExplorerApr 10, 2014Adding BR A/C to Styrofoam insulated roofI have removed a Fantastic Fan from my bedroom vent. I have run the 120 Volt wiring from this vent to an 20 Amp outlet I installed in the side of my 5th wheel. I have purchased a 13.5K Coleman Mach ...Show More
B_SjulestadExplorer IIApr 11, 2014I thought the fantastic fans were 12v if so then the wiring for the fan will not support a a/c unit.
Related ContentAdding power outlets in slide with no wiringStyrofoam vs fiberglass matt insulationReplace insulation inside heater column.Remodel insulationFront cap added insulation
