agwill
Nov 08, 2021Explorer
We need more information, to give a good reply. Are you running the fridge on gas or electric? What about the hot water heater? What type of lights bulbs are you using. Do you use a inverter to power your ac devices? What type of batteries are you using? Size 24,27, standard lead? Sounds like you have a very small solar panel that will only trickle charge your battery. Basically useless if so.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
