jffnkrn
Nov 09, 2021Explorer
good point and i will add, if your vehicle is wired correctly, you should be able to plug the trailer in, after starting your vehicle, just in case, and it will charge the batteries. the vehicle normally is designed to charge while driving, so put your jacks down and put your slides out while plugged in if you can, of course unhooked. In the meantime, you can also plug the truck into the trailer and give the batteries a little extra umph that may take care of you with the solar panel and get you through the couple days. the fridge mostly is on propane, shouldn't need that much juice. you will know if your truck is charging by turning on some lights, then plug the truck in and the lights get a little brighter. good luck, have fun ! ! !
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
