time2roll
Nov 20, 2021Nomad
I have a small 700 watt Ryobi propane generator just to keep the battery up if the solar should prove inadequate for an extended period.
https://www.ryobitools.com/products/details/46396019240
Been rebranded as the Baja at Home Depot.
https://www.homedepot.com/p/Baja-900-Watt-Propane-Powered-Inverter-Generator-BAI911LP/306283803
I prefer to avoid the gas can and storage issues of gasoline. I added a fitting to connect to my existing propane. Very light. I think the noise is on par with a Honda when running under load. None are exactly quiet and it does idle down when minimum power is needed. Although it is small enough that it could be overloaded with many converters. May need a small battery charger in the 20 to 30 amp range. Works for me.
BTW I replaced my 4x GC2 like this:
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
