sdetweil
Mar 16, 2015Explorer
Stefonius wrote:sdetweil wrote:I got my information from the manufacturer of the fifth wheel. They gave me the Cummins part number, and I was able to look it up that way. The local Cummins dealer is terrible at returning calls, but I was able to walk in and make an appointment for service/installation.Stefonius wrote:I am installing an Onan 7kw genset in my non-prepped FW as we speak. I have the floor cut template, got the box built, have run the power cord from the genset location to where the ATS will be (and power mgmt/suppressor box) (have both boxes now), just thinking thru the genset mount.. I'd love to see any info on that 'mount'.sdetweil wrote:Sadly, no. I called the manufacturer and spoke with one of their engineers. He told me that all of the generator prep is done with a specific list of parts obtained from Cummins/Onan, and sent me a copy of the list. Basically, it's a metal box put inside of the front compartment, a mount from which the genset hangs, a transfer switch, a higher flow LP regulator, LP supply lines with larger inside diameter, and a remote start switch with hour meter.
is your FW generator prepped?
Any of the Cummins/Onan service outlets nationwide can do the installation, as they have the parts. This is the quietest and safest way to go. The unit is designed to get intake and cooling air from underneath, and the exhaust pipe runs under the compartment and opens on one side of the RV. I'll put a Genturi stack on when it's in use, so that I don't have to worry about it.
I converted my unit to LP. and will use the Onan EC30W wireless remote start kit as it adds a set of function over the wired remote start.
edit: I have called both the local Onan office and Camping World 3 times each for estimates on the install, and they do not return call as they promise or remember that I did call before.
You need an "Underfloor Mounting Kit" for your genset. I think it bolts to the underside of the floor at the top of the front compartment. The genset basically hangs from the sides of it. See the appropriate section of this document: Cummins Accessory Catalog (pdf) This mount is separate from the airtight box that seals the compartment from the inside of the RV.
Hope that helps!
thanks.. I don't think the underfloor mount kit is right for this application. there is no room under floor for this genset..
usually they look like this
the box looks like this
in either case that bracket kit won't work.
my issue is that the genset weighs 290lbs, and once I get it into the box, 3.5 inches down over the lip in the front baye, I don't know how I would ever get it out if I needed to service it.
I am considering two ways to mount it, after cutting the air intake and access holes (change oil and filter) in the floor.
1. use 3.5 in square tube to set the genset on, level with the front compartment edge. (a 4x4 is the perfect size, but don't want wood in this application)
2. in addition to the 3.5, use some heavy duty drawer slides to be able to pull the unit out of the front bay. (they support 500lbs)
due to the limited room, you cannot get the enclosure off the unit with the unit still in the enclosure..
once I lift it off the front bay floor, I need to create some ducting so that the hot air from the engine fan blows out the compartment completely.
About Fifth Wheel Group
