Bumpyroad
Aug 27, 2013Explorer
laknox wrote:
I've thought about this with my Komfort and agree that the exposed prongs could be dangerous without a transfer switch. Just had a thought, though (always dangerous). What if you got a female plug, stripped the contacts out of it, and used it to cover the male prongs inside the unused recep, then dropped the cap down over that?
Lyle
can the cover/cap be closed with both items inside it? would be better with some type of lock on the cover. main problem is that some body will come around and defeat your safeguard, then you could be in a heap of $$$ trouble.
might be safer just to use a female receptacle twist to lock on and screw ring to hold it in place. then somebody would have to unscrew the ring, twist off the receptacle, and then grab the contacts?
bumpy
About Fifth Wheel Group
