TH TT all seem to have a fairly high tongue weight, so be sure you are set up to handle the weight. My 26' Energy TH had a dry tongue weight of 1,150 lbs. Never checked it when loaded with toys and 100 gallons of fresh water. Sure it was well over 1,200 lbs. I had enough truck and hitch to go well past that, so I never worried about putting it on a scale. Just be sure you are set up to handle whatever you are looking at. I wouldn't worry about hitting all the weights right on, but try to keep it close.
