Gebrown's avatar
Gebrown
Advice ?
I'd first like to start off with an apology to anyone I've annoyed by asking so many questions so fast. I'm just anxious and nevervous about all this at the same time so I have a lot of questions and concerns.
After reading advice on here and doing research I've come to the conclusion to eleminate certain TH's like the Coachmen 301BLDS and some other heavier models.
Howver, I do have one more bigger size TH question though so please bear with me. What do you think of a 30' 6023 UVW Hyper Lite 27HFS? To much?
Or I am now looking for at the open floor plan modesl like the KZ MXT 20? Any recommendations on those brand wise?
Any help is appreciated, I'm trying to do what's best for me, my family and others around as we attempt to get into the RV community.
Thank You
  • Depending on which model of 1500 you have a tow rating of roughly 5200# with a payload rating of about 1300# (minus weight of people/stuff in truck)
    More info here.......LINK
    Just keep in mind that you will run out of payload and reach GVWR before you reach mfg. tow rating
  • Okay, found one, well actually two, both are White Water (?, never heard of that brand), one is an 826 and the other an 827. Both are 27' and weigh a little over 4K lbs according to the site.
    White Water 826:
    http://www.tulsarv.net/pre_owned_detail.asp?veh=3726405
    White Water 827:
    http://www.tulsarv.net/pre_owned_detail.asp?veh=3785245
    What do y'all think?
  • Also, I don't plan on putting water or fuel in it until I get to where I'm going.
    But I do have a 688lb 4 wheeler I'd like to take with me places if we want to, that's why we're looking at TH's.
  • Old-Biscuit wrote:
    Your question about whether it is too large is kinda like asking how long is a piece of rope..without more info everything would just be a guess.
    What is your tow vehicle?
    How much actual payload do you have?
    TV:
    2008 Ram 1500 5.7L
    Tow pkg
    6" lift w/35" tires
  • Your question about whether it is too large is kinda like asking how long is a piece of rope..without more info everything would just be a guess.
  • TH TT all seem to have a fairly high tongue weight, so be sure you are set up to handle the weight. My 26' Energy TH had a dry tongue weight of 1,150 lbs. Never checked it when loaded with toys and 100 gallons of fresh water. Sure it was well over 1,200 lbs. I had enough truck and hitch to go well past that, so I never worried about putting it on a scale. Just be sure you are set up to handle whatever you are looking at. I wouldn't worry about hitting all the weights right on, but try to keep it close.
    Thank You
    It all comes down to the weight, GVW, GCW and tongue weight. That being said a 30' tag trailer is one big momma! I would not want to pull it with my 2500HD Duramax, let alone a 1/2 ton. To me not a comfortable tow.
  • I have a 2011 KZ Sportsman toy hauler that I've had for 2.5 yrs and it has been a great unit. Not real fancy but well built. From my research, KZ builds light weight units that do not compromise quality of construction. The two year warranty is very nice also. Mine has thick, real plywood flooring and roof. I was just on the roof Monday checking my caulking and I don't feel any "give" in the roof when I walk on it. For extra safety, I upgraded to E rated tires, as my rims were rated for 80 pounds of pressure. The axles are plenty strong in terms of their rating.
    The negative is a somewhat light carrying capacity. With the options on mine I only have about 2,300 pounds of carrying capacity for a 8,000 pound maximum.. This works for me as I don't travel with the water tank filled or heavy bikes. But, two Harley's and packed up would definitely be pushing it.
