2-MTnesters
Jul 23, 2014Explorer
B.O. Plenty wrote:chiefward wrote:It's refrigerant not coolant. They are sealed units, no charging port. All you can do is replace them.
Get your ac unit serviced. May be low on coolant.
B.O.
This is not necessarily true, Locally there is an HVAC guy that for $75 will cut the crimped ends off of the Freon lines, sweat new service connections on and re-charge the system all without removing the unit from the camper. I'm sure if you call an heating/air place local to you they may do the same service. Tim
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
