UncleFudd's avatar
UncleFudd
Advice on Sizing truck Requested
First we want to thank all of you for your advice getting us from our motor home to the fifth wheel. RV folks are the best, always been that way.
Now we have reached the stage of configuring a tow machine for the Cedar Creek 36 CKTS w/TrailAir Air Ride pin box we have ordered. Dry weight of 36CKTS listed as 12,076, GVWR 16,389. GCC a huge 4,313. Hitch wght 2389. We travel lite, realizing long ago that nothing rides free our cargo would add way less than 2,000 lbs.
Hitch selected is Demco Hijacker 18K Autoslide setup to "plug and play" w/Ford 5th wheel Trailer Tow Package that includes under-bed-frame crossmember and attachment points. The Hijacker does not require a pin box adapter with the TailAir and weighs 350 lbs.
Truck will be Ford 4x2,6 3/4 short bed crew cab w/diesel. The puzzle is which truck is enough to safely tow the trailer with a reasonable margin. Both the F250 & F350 crew cab show 5th wheel towing -max. loaded trailer wght at 16,300. Brakes are same, wheel size 18". Rear axle rating F250 6,200 F350 7,280. The confusing area is GVWR F250 4x2 10,000, Payload weight rating 3,640. F350 GVWR 10,000 Payload rating 3,610. The F350 brochure chart also lists F350 with GVWR 10,200 Payload 3,810, GVWR 10,700 Payload 4,260 and GVWR 11,400 Payload 4,300.
These must be available options but the online build your truck only has the 10,000 as the F350 GVWR. The other weights are not offered as an option. The F350 costs $900 more and would ride rougher than F250. Would the F250 work with rear air bags added or should we go with the F350 at one of the higher GVWRs assuming they are available?
Please relying on your experience and expertise to get this right without going to extreme. As you are aware it is important to get this right the first time, driving the rig onto a scales unfortunately is after the fact not a good thing.
As always Thanks for your help,
Jim
  • My 2011 SRW 350 is 11,500 GVW with an empty weight of 8040 from Ford. IMHO you're talking dually.
  • I believe it would be OK with the 350 SRW, IF, and only IF, you get the max. rear axle capacity available. It will be close though. But, it will be OK. If there is ANY chance of more stuff, or going to a bigger trailer, then the dually would be a must.
  • Old-Biscuit wrote:
    The SRW is a good towing platform BUT has it's limits.
    Any trailer over GVWR of 14K is pushing those limits.
    I think realistically you would be much happier towing that 5vr with a F350 'dually'
    I tow a 5'vr that weighs 13,830# (scaled) with a 3500 SRW.
    Any heavier I'd need to step up to DRW
    I agree with Old-Biscuit and JMTandum, you need to look at the diesel dually crew. I like to over-engineer a little bit on my TV because you don't know that conditions will always be ideal, and you are right at the edge on specs, slightly over actually. If I had to navigate an ice storm for instance, I would hate to take on the challenge with an overtaxed TV hauling a few hundred extra pounds of ice. No-I don't ever plan to be in that predicament but it has happened to me.
  • First we want to thank all of you for your advice getting us from our motor home to the fifth wheel. RV folks are the best, always been that way.
    Jim
  • The SRW is a good towing platform BUT has it's limits.
