guinness1's avatar
guinness1
AGM upgrade
I have a 2012 Coachmen Chaparral. The original battery finally died. Can I upgrade to an AGM battery? Any other changes need to be made? Or is just “Plug N Play”?
  • You can change to an AMG. However, as others have written...
    “AGM batteries are designed to be charged at a low rate and slowly. Unless your converter/charger can tell difference between an AGM and flooded battery it will charge the AGM like it's a flooded battery, which will work but it also will shorten the life of the battery.”
