MN_Ben
Feb 21, 2017Explorer
RainbowsEnd wrote:
"Wirelessone: If both bags are on one valve the air will shift from one to the other while turning with a heavy load. However, if the load is distributed evenly it will also return to even once you straight out."
In theory, probably. In reality, you will never notice it.
My Airride system is T'ed together. Mine is "wired" to the supplied pressure gauge in the cab. I can fill or defleat with the push of a button on the gauge and constantly monitor the pressure at a glance as I drive. I am totally happy with the system and kind of glad I did not go the wireless route. I use it in the set up in my signature as well as heavy brick loads. Also had the system in my SRW setup.
Ben
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
