RainbowsEnd's avatar
RainbowsEnd
Air bag wireless air compressors
Still working on the decision between Firestone vs Airlift kits and the wireless compressors. Today I was reading about difference in WirelessAir and WirelessOne. I understand the difference of single or double pass. Just not sure of real pros and cons of either while hauling a 5th wheel. The truck is only used for the 5th wheel and not other hauling.
The reason I ask is because of reading comments like:
"Wirelessone: If both bags are on one valve the air will shift from one to the other while turning with a heavy load. However, if the load is distributed evenly it will also return to even once you straight out."
Anyone with experiences on either of these systems? Any concerns with using the WirelessOne?
  • Planning wrote:
    I have the Firestone Air Bags. I had them put on by the RV dealer upon delivery of the 5er as soon as I saw the rear end squat.
    The more progressive spring rates allow more sag to compensate for a softer ride.
    The bags make it very easy to level the 5er.
    I had them installed with manual air fittings at the license plate area. Separate lines for each side.
    I am planning to install the Firestone Wireless Air Command F3 in a few months. My plan is to use the Firestone 2588 "No Drill" mounting plate, and use a Group 27 battery box as a weather resistant enclosure for the pump and ECU.
    I plan to install "T's" into each air line to keep the manual fill option intact.
    You might want to check out the AirLift 72000 wireless compressor system. Have had installed now for two years, and has worked flawlessly.
    Its never a bad idea to add the manual fill lines. My system came with the air valves to install in the license plate bolt holes. Never know when something can go bad on the compressor or control system.
  • Due to many of the failures of the wireless compressors a while back, I went with the Firestone Ride-Rites and the Viair 10007 onboard air system on my truck. I realize that the wireless compressors have come a long way in the past 6 years, but I'm on my second truck with the Viair. I have them plumbed independently and can control each bag from the cab with the Firestone pneumatic controller. Plus, I put an air chuck under the right rear door of my truck so I can fill tires anytime on the road.
  • medic143,
    How/what did you use that enables control of the Viair to the Firestone Ride rites?
  • Planning wrote:
    medic143,
    This is the dual pneumatic gauge controller that I used. It is a little pricey, but I've never heard of anyone having a problem with one. I had another style and promptly switched to this one and have never regretted it. It is also available in a black face as well.
    Firestone Dual Needle Control Gauge
    I have had two different AirLift compressor systems. One was the conventional one with a gauge the second ,and present one is wireless. Nearly 10 years with both, and they worked flawlessly.
    Just curious what kind of problem you had with the wireless.
