- 2oldmanExplorer II
gutfelt wrote:
Sure, but "cold" can change.
u set tires cold on your Class A MH based on the weights you carry etc and as long as circumstances regarding those parameters stay the same you should never have to adjust assuming they don't leak of course - Mile_HighExplorerI carry mine because I already had it with our 5er and it is a good general purpose compressor for multiple things - airing back up the Jeep tires after off road, winterizing, grandkids stuff, water toys, bikes, and the RV tires. Sure the on board compressor can do some of that, but the engine has to be running and not worth cold starting the Cummins to air up a bike tire.
So its not about not fixing flat tires, but if you are going to buy a compressor you might as well have one that can air up the rig tires, because the on board compressor won't do much better than 100 psi and my portable does 150 psi with a far better CFM than most (fast recovery). - gutfeltExplorer
2oldman wrote:
JaxDad wrote:
Your air pressure never varies with the changing temperature?
I’m still trying to figure why people don’t just fix leaking tires. The last time any air went into any of my tires was when they were put on the rim.
matters not;; u set tires cold on your Class A MH based on the weights you carry etc and as long as circumstances regarding those parameters stay the same you should never have to adjust assuming they don't leak of course - 2oldmanExplorer II
Mile High wrote:
I don't understand. I can go to any of these sites without signing in or out at all. I don't know what you mean 'venture further in'. It's just a simple link to one thread.2oldman wrote:
Not till you venture further in, then you realize you're not in rv.net anymore.Mile High wrote:
That must mean you. You're signing out?
You guys keep throwing people into the Open Roads threads and they aren't signed in anymore. - 2oldmanExplorer II
I’m still trying to figure why people don’t just fix leaking tires. The last time any air went into any of my tires was when they were put on the rim. - jplante4Explorer II
seriously I think some of these guys check their AP so often they cause the problem; in reality they should never lose more than a few pounds in like 3 or 4 years; my right front looses about 5 lbs in a year and my left front zero;I think I put air in the rears like twice in 7 years so I agree with you
This was certainly the case for me. Every once in a while the sand from the Equal tire balancer would stick a valve open. Since I put on TPMS, I haven't had to add air.
I finally dumped the spare tire I've been lugging around for 3 years. I still carry the compressor though. - 3oaksExplorer
JaxDad wrote:
I take it you never developed a slow leak while on the road or never strayed very far from a metropolitan area with tire service was at your fingertips.
I and am sure others, always have a leaking tire or wheel repaired at a opportune time. However, those services are not always available or convenient at the time and place like in remote areas.
Thus, the discussion concerning portable air compressors. - gutfeltExplorer
seriously I think some of these guys check their AP so often they cause the problem; in reality they should never lose more than a few pounds in like 3 or 4 years; my right front looses about 5 lbs in a year and my left front zero;I think I put air in the rears like twice in 7 years so I agree with you - JaxDadExplorer IIII’m still trying to figure why people don’t just fix leaking tires.
The last time any air went into any of my tires was when they were put on the rim. - gutfeltExplorerlike I tried to explain hit shift when you click on the link and it will open without signing out of current location although the link is the same user name and password and add to that if u use the right settings your current location will always keep u signed in
38,782 PostsLatest Activity: Sep 19, 2026
