rtazz17
Apr 01, 2014Explorer
Yeah not for the front.That would give you a teeth shattering ride as well.
Those will def stiffen up the rearend as well.
Airbags are a better option imo in that you can change the pressure when you are unloaded so you dont have to have that still rearend all the time.Ive had them both and airbags win hands down.
But if money is an issue go with timbrens.Def much much cheaper.Especially if you add an onboard compressor to inflate and deflate bags which again imo is the way to go long term.Just soooo much easier to do.
You might want to see how it rides first but im thinking those leaf springs are getting tired at this point and you may sag quite a bit.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
