I am wanting to add onboard air and self leveling air bags on my 13 F250. Has anyone here done this? If so looking at options and wondering what worked best for you. Doug
I went with https://www.airliftcompany.com/products/other/aircell/ I've used air bags in the past with good luck. This time around I decided to go with Aircels. Super easy to install. No lines to run and the ride empty is the same as stock. Even when airing down my bags in the past to the min 5 psi the ride was still a little stiffer than I liked.
