batmack
Nov 27, 2014Explorer
Air bags
My 5th wheel RV dry weight is 7530 lbs and loaded is 9950 lbs. Truck is 2014 F250 6.2L 4X4 Crew cab (max load 12,200 lbs). Would there be any benefit installing air bags on the truck ?
Us out West wrote:Cummins12V98 wrote:Cummins12V98 wrote:Us out West wrote:
We have 'bags' on our TV but don't use them.
Why?
We have the right truck to pull our rig.
Just saying....
Just curious do you run 5psi when running solo in the bags?
Well I was trying to make a point if he came back and said he ran 5psi solo. I run 5psi solo but when the RV is attached the pressure in the bags goes to 30psi and that is where I leave them while towing. That PSI does not change the ride height but does help with spring control. So while he says he does not use them I am thinking he does.
Good point.
Haven't checked bag pressure in years...my bad but will look.
Thanks.
