My 5th wheel RV dry weight is 7530 lbs and loaded is 9950 lbs. Truck is 2014 F250 6.2L 4X4 Crew cab (max load 12,200 lbs). Would there be any benefit installing air bags on the truck ?
Bought a 2011 F250 6.7. At the time there was very few 6.7 on the lot. Had to trade as the used truck I bought had a bunch of electronics added and missed it up. So I took the F250 and found it was very inadequate. Added air bags as necessity. They did the job, but found the ride empty was really rough. I would lower to 10 psi when empty. Finally traded for a DRW and that is the answer.
