C7XR7
Aug 18, 2015Explorer
Something to check. Be sure you are getting really good air flow both in the condensing unit and through the evaporator coil. While not as important for heat, AC requires that you have good air flow. Clean filters, all duct work open, no collapses, good fan. Up top make sure the condensing unit is clean, fins are not bent closed and so on.... You can leave the fan switch in the ON position for AC. Have you had this unit serviced where they hooked the gauges to it?
The hunter21 wrote:
I have a 2003 Keystone Challenger with a Carrier AirV air conditioner. It doesn't seem to cool the trailer like it should. I have had three servicemen look at it and they all say its working fine. Yet when I am in a campground, my camper is warmer than everyone else and they all have water running off theirs, I only have a slow drip. Any suggestions?
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
