- fj12ryderExplorer III
racer4 wrote:
That's the one I have and it works very well. It isn't as loud as some of the other small compressors, and it reaches max pressure very quickly. And I've had it for 5 years and still works as well as when it was new.
This PORTER-CABLE CMB15 works for me. - pcm1959ExplorerViair 12v. Compact, not super fast but it works for high pressure. Have had it 7 years. Great when 110 power may not be available.
- ChainwrightExplorer
- racer4ExplorerThis PORTER-CABLE CMB15 works for me.
- +1 for viair as you go over 80psi.
For the big dog look at oasis that will produce 200psi continuous and pull 180 amps from your battery to do it.
http://www.oasismfg.com/dc-air-compressors.html - theoldwizard1Explorer II
romore wrote:
Many small compressore are capable of 115 psi but lack the volume to produce much air at that pressure. You want volume and pressure but that comes at a cost in bulk and weight. And price.
The Milwaukee M12 inflator will go to 120PSI, but it will take a long time. They also recommend running continuously for more than 10 minutes.
If you are just "topping off" tires that are down 5 or 10 psi and are not in a hurry, it might be for you. - romoreExplorer IIMany small compressore are capable of 115 psi but lack the volume to produce much air at that pressure. You want volume and pressure but that comes at a cost in bulk and weight. And price.
- MFLNomad II
This is the one I use. It has quality fittings and gauges, and quickly goes to 165 psi. It is also light weight, about 35 lbs.
Jerry - ChainwrightExplorer
TimnJo wrote:
I've heard good things about compressors from this company, a little too expensive for my budget though.
https://www.viaircorp.com/portables
Wow, $280 and up. You ain't lyin' - TimnJoExplorerI've heard good things about compressors from this company, a little too expensive for my budget though.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
