ford_truck_guy
Aug 03, 2019Nomad
debili wrote:
Thank you I was up there but could not figure out where they were...water is running off except on side and as I said now today it isn't even leaking...this is crazy
Once you take the four screws out that hold the shroud on, remove the shroud. You will see a metal tray with rounded edges that everything is sitting in, that is where the whole should be but in all four corners.
About Fifth Wheel Group
