Old-Biscuit
Aug 03, 2019Explorer III
The weep holes are in the drip pan that is UNDER the EVAP Coil
EVAP COil is in a SEALED compartment Under the roof shroud
You HAVE to OPEN that sealed compartment to access the evap coil drip pan and might have to shift evap coil a bit to get to drain holes to clear them
(cut the tape..remove screws, remove cover. Seal back up after cleaning drip pan AND EVAP Coil)
Look at diagram posted
Evaporator Drain Pan, Evaporator, Room Air Fan.....UNDER the SEALED Cover
(Motor, Condenser, Condenser Blower etc UNDER the roof shroud)
About Fifth Wheel Group
