bigblue1234ExplorerApr 04, 2014Ajust slideHow to adjust living room slide on 2002 Cardinal? One side of the room goes out to far. It is "HYDRAULIC" Thanks.
C_SchomerExplorerApr 04, 2014I've only had one hydro slide and it had equalizer cables to keep both ends even. You might have have cables or something else to adjust to even up the ends. Craig
Related ContentEasy way to remove slide topper?arctic fox slide adjustmentB&W Companion Hitch ajustmentslide out 120v harness issuesSchwintek slide jammed - shifted back
