griffy00
Jan 17, 2016Explorer
Are your valves made by DrainMaster? If so, they have a manual override. Their valves either require a screwdriver (older valves) or an allen wrench. If they are the older valves you can easily strip the screw head. You will have to remove the underbelly to gain access to the valve. You will also need a flashlight to see which direction to turn the manual override because it's hard to read the imprint in normal light.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 23, 2026
