Veebyes
Jan 19, 2016Explorer II
The OP most likley has another complication if identical to mine.
No separate dump hose to hook up everytimea dumping is required.
The dump hose is permanently hooked up & retracts inside a pipe which is inside the belly. Nice & neat but you need to get close to the dump to use it as the hose only extends about 8' from the storage compartment.
My life with a sticky valve is the same as Durb's. The Allen wrench is kept in the truck, where it is handy, & a tarp to put on the ground is also handy along with tape to reseal the belly.
The DW & I have gotten quite efficient at dealing with the sticky valve. We are faster at the dump than most who have to do the get the hose out routine.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
