Me Again wrote:
Dry pin weight is 2650 and GVWR is 15,500. Loaded you will have to watch rating of rear tires very carefully. Not sure you will like performance of a V-10 with that kind of weight.
What is the rear axle weight rating on your truck. You will be looking at around 3100 pounds of pin weight, a couple hundred for 5th wheel hitch and more for stuff in the bed. If you have a 6000-6200 RGAWR you will most likely exceed it.
We have a truck with a 7K RGAWR and have a similar size trailer that started with 200 pounds less dry pin weight and we are pushing close to 7K on the rear axle.
I see a new truck in your future if you want this trailer.
Chris
'04 F350 has a rear axle rating of 6850. Payload ~3000lbs.
