Cummins12V98
Oct 22, 2013Explorer III
Weigh all 4 tires independently if possible when the RV is fully loaded. Use the heaviest tire and look up the tire pressure recommended for your tire size and load range. Then use the next higher pressure recommended.
All this is per GY Tech Support.
I ran GY G's on my Avion Platinum at 80-85 psi when the original tires were GY E's and the wheels were rated for 80 psi. After 5 years the tires were wearing perfectly even.
Same goes for tire pressure on your TV. Most think they should run max when towing, that is not always true. I run 45 unloaded and 60 loaded on the rear duals on my truck and 80 in the fronts at all times. RV pin weight at over 4,500#.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
