ford truck guy wrote:
cummins2014 should be commenting shortly... He is an advocate for the Anderson and Ram..... He will be able to answer
He should be a good source of information, for what the OP is asking. I don't see a lot of options for the Ram axle center to cab, being a short distance. I don't know if this Ram has the puck system, or if rail system is being considered, but I do not think a single point attachment is the best option. IMO, Andersen with rails may work, a B&W Patriot with rails, adjusted to rear setting, may work. Using a standard hitch, with a sidewinder type pin box will work.
The OP is a pretty smart guy, and is asking lots of questions before taking a leap. Once he gathers good info from others, I think he will make the best choice available. Moving to a used diesel, I think his truck choice is a wise decision.
Jerry
