cummins2014 wrote:
Durb wrote:
OP, back on topic. I talked with a man at a campground a couple of years ago with a new, high end, Ram and a new Montana High Country trailer. He wasn't too happy, his cab was dented and his rear window was gone and taped over with plastic. His Andersen hitch in the rear position was allowing his pin box to bite chunks out of his tailgate so he reversed the adapter. He happily towed for many miles until he lost focus on a tight back up combined with a driveway dip. The Montana does indeed have rounded corners but the trailer slopes forward from the overhang. When he went into the driveway dip the trailer leaned forward and took out his window. His dented cab was near the roof. You may want to keep this in mind.
Look at the Blue Ox Super Ride instead. It will hinge rearward when you need it.
I agree, if you blindly back up ,and not pay attention you are going to get into trouble. That was my concern with the pinbox being to close to the tailgate . If I would have had time on that first tow with the new fifth wheel I would of trimmed the corners on the pinbox , instead as said I reversed the adapter. I have no issues with it reversed . The combination of the pinbox placement on the fifth wheel ,and the rounded corners I don't plan on reversing it or doing anything with the pinbox .
I too have a driveway with a dip , and a street that is a bit too narrow to be able to back in gradual . I have to crank it pretty tight ,but still not a problem.
Good points.
Where the hitch was located in the bed ...
how the back of the pin box was shaped...
length of the pin box...
pin box location
...are all unknowns.
Apparently most Andersen users as you don't have these issue.
