JIMNLIN wrote:
Good points.
Where the hitch was located in the bed ...
how the back of the pin box was shaped...
length of the pin box...
pin box location
...are all unknowns.
Apparently most Andersen users as you don't have these issue.
Its usually just the ones that are not paying attention ,and takes out a back window or dent their cab are the ones with the issue of their own doing.
This Andersen does give you more clearance than a conventional hitch or a manual slider. Of course a manual slider does, when used ,but how many times have we read where they took out their window or dented the cab because they didn't use the slider. Its not the hitch at fault here .
The hijacker did take longer then usual . :R
