cummins2014
Feb 27, 2018Explorer
4x4crazy wrote:
I've been looking at hitches for a fifth wheel and out seems like the andersen hitch is the way to go. I like the idea of easily taking the hitch in and out. I have a 2017 f250 diesel with the fifth wheel prep package and I'm trying to decide on model. It looks like the ultimate model covers the pucks where I'd want to hook up the safety chains. The rail model seems like I can get the puck adaptor and tie the safety chains to. Anyone have recommendations? I'm only looking at a 10,000lb or less fifth wheel so I think either model works. I have a short bed and it seems you can put the offset to the back and not use a slider, is that right?
I went with the rail mount Andersen, and the Reese picture frame that fit the OEM fifth prep on the Ram trucks, same as the ford. I already had the picture frame, so the rail mount Andersen was the logical choice for me. I would still go that way, just don't like the gooseneck version Andersen.
With the rail mount Andersen I would go with the Reese picture frame adapter I believe its the least expensive . With a conventional hitch the Reese adapter cannot be unhooked in the pucks the hitch gets in the road to unlock, the handles, so you are unable to remove the hitch , and adapter in one unit ,if you were using a hoist. The Demco is the better choice with a conventional hitch, the locking handles can be released to enable the hitch to remain attached ,and both removed together. With the Andersen being light weight it makes no sense to remove both at the same time.
I have no issues with my short bed , and the Andersen. I have it in the offset to the rear. Plenty of clearance for turning ,and backing.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
