Wingnusa
Aug 21, 2014Explorer
Andersen Hitch
Anyone out there have one of these? I could use some feedback on the Ultimate. I especially want to know how things ride inside the rig when you have this hitch...
Housted wrote:
"Any jerky stops or starts put additional stress on the bed floor."
Not true, the Turnover ball has a very large cross member in front and behind the socket. They are securely bolted to the frame and provide support under the bed for both hitches equally. I have had both and will keep the Andersen. Neither of them rest solely on the bed.
Housted
Me Again wrote:
Well I guess you failed HS physics as you can not pull and push at the same time.
Wingnusa wrote:
No one has entertained the original post when I asked about stuff moving around INSIDE the 5er... Has anyone noticed any difference on how much stuff has moved around vs a conventional hitch. I'm being told by someone that the 5er will ride as well or better than having an air hitch. I'm having a tough time with that one...
N-Trouble wrote:
Sorry but chucking has EVERYTHING to do with the hitch...
If your concerned about 4500lb pin weight this should ease any concern: https://www.youtube.com/watch?v=78l-PadWAro
I have yet to hear anyone who actually "uses" this hitch complain about it, only doubters who can't get over the concept that something so light, simple, and cost effective can be up to the task.
You'll also hear many refer to it as a GN and how it will create additional forces on the kingpin which is entirely untrue. THe fact that the ball is raised makes it no different than any other 5er hitch in this regard.
Me Again wrote:
Also seems a wind blow over could occur easier with the Anderson hitch, as it would go much farther before the trucks weight and stability came into play. Chris
