Wingnusa
Aug 21, 2014Explorer
Andersen Hitch
Anyone out there have one of these? I could use some feedback on the Ultimate. I especially want to know how things ride inside the rig when you have this hitch...
Me Again wrote:Have you ever even seen a B&W hitch in operation?fj12ryder wrote:
Probably not an issue because the weight of the 5th wheel is not carried on the bed. Most of the weight is transferred through the pin to the frame members.
If you're were carrying the full weight of a large, heavy 5th wheel in the bed only, you'd have some serious denting issues, not to mention probable failure of the bed in several places.
Guess what that is how a B&W Companion and Anderson hitch works, the pin weight is on the floor of the bed not the turnover ball. Some of you need to go back to school!
Watch this video. The pin goes under the shoulder of the gooseneck ball, and then the bolt is tighten, pulling the high down the the bed floor. If it gets compress enough the pin will just move away from the shoulder of the ball. Very simple process with nothing to transfer downward weight to the ball. B&W works in a similar fashon.
http://www.andersenhitches.com/Catalog/ultimate-5th-wheel-connection.aspx
Chris
Me Again wrote:
Anderson really hedges on the requirement for safety chains! I would get tired along with my front jacks with the extra lifting to couple or uncouple it. Trailer has to be lifted and extra 3 or 4"!
I would like to see one after a wreck? Compress test is testing it in a single direction at it's strongest point.
Like the B&W Companion I am not convinced placing hitch loads on sheet metal beds is the best long term design!
Traditional 5th wheel hitches when correctly installed put the load on the frame rails.
If I get a new RAM it will have factory prep and a four puck hitch that locks onto the frame.
Chris
jus2shy wrote:
I agree with Me Again in the theory of how these gooseneck mounted hitches work in the bed of a truck. That's also the reason why B&W does not advise using the Reese "Sidewinder" with their gooseneck-based 5th wheel hitching system. However, there's no caution for the hitches that utilize the rails or the OEM "Puck" mounting systems. It's just too much torsional force on the goose neck shank when presented with the additional leverage arm of the sidewinder and certain conditions could lighten the hitch from the bed causing excessive twisting and not enough clamp load to keep the hitch oriented correctly. For every force, there's an equal and opposite force. So as you pull up the slack from the gooseneck ball which is being pulled-up from the truck, the hitch (B&W or Andersen) is pushing down onto the truck's bed which is building a clamping force. So the square gooseneck shank coupled with the friction of the hitch base and bed are what prevents it from spinning.
There is only 1 concern I have with the Andersen vs. the B&W Companion. B&W added extra material on their companion hitch to take into account the bed ribs (for lack of a better term), so it doesn't flatten the higher standing portions of the bed with the lower portions. The Andersen doesn't seem to take that into account. I would be concerned over slowly flattening the bed with a loaded hitch. Has Andersen addressed this possible issue?
Also, I'm thinking about adding the Ram's "Puck" system to my truck since it can be retrofitted. Seems like this would open me up to using the sidewinder hitching system which I think would be a home run since that would give me a full 90* turning radius regardless of the trailer nose. Still weighing my options personally.
And in case people don't believe me regarding the tortional force, here it is straight from the horse's mouth.
And in case other RAM owners are curious, appears that the mopar part number for an after-the-fact 5th wheel prep install is 82213665AB.
stewks wrote:
I was able to rotate the Andersen hitch around to get the best clearance (about like a no slide hitch).
