cummins2014
Jun 25, 2017Explorer
Searching_Ut wrote:
For those unfamiliar with the Andersen Ultimate hitch, 100 percent of the weight of the trailer is carried by the bed of the truck, and none is carried on the ball in the bed of the truck. The truck bed ball is used as an anchor point with a pin that goes under the ball to anchor the hitch. You then tighten a bolt on on top of the tube that pulls a tub within the tube to pre-load the the base tightly against the bed of the truck. The truck bed ball is used for pulling to pull the hitch down, not to support the weight.
The other thing to keep in mind is that all of the pin weight for the trailer is transferred to the two set screws on the pin adapter between the ball and pin. The pin box not being designed to support the weight in a small area rather than distributed across the pin box base plate is what resulted in damage to my bighorn.
Is this a wide spread problem, damage to the pin box or just yours ? Yours is the only report I have read about with this problem.
I ask because I'm waiting for the puck system Andersen, which IMO will be an unbeatable fifth wheel hitch.
If your issue is in reality a problem for others , it wouldn't take much to beef up a pin box.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 18, 2026
