Me Again wrote:
ralphnjoann wrote:
Well, for one thing, the Andersen hitch does not cause "100 percent" of the weight of the trailer to be carried by the bed of the truck.
Second, the pin weight is carried by a ball mounted on a cross member secured to the rails of the truck. Snugging down the hitch so it doesn't shift does not place pin weight on the bed. That 40 or so pounds of force is there whether or not a trailer is attached.
Finally, the problems you had with your pin box must not be widespread since yours was the first and only one I have read about on these forums.
You can not pull down and hold up with the same mechanism.
I don't think it's exactly the same mechanism serving the same purpose. The nut on top of the tube screws down on top of the ball forcing the base to likewise be pulled down on top of the bed floor. This is accomplished by pulling up on the ball but the hitch pin that attaches the Andersen to the gooseneck. The weight is not carried by the ball in the gooseneck at all. But the weight is carried by the gooseneck hitch rails and the frame of the truck. The only thing in common is that the ball is in the gooseneck receiver.
For some to say there is only some weight on the bed is untrue. Nearly all of the pin weight has to travel through the bed floor. The force distribution starts at the kingpin adaptor, through the ball on the top of the Anderson, through the pyramid frame to the base feet to the bed, to the hat channels, to the gooseneck hitch rails and the truck frame rails, through the suspension, to the wheels and tires, and finally to the ground. If I understand the distribution of force correctly in this application.
There is no single path for the weight to follow to the ground...it passes through all the equipment...even the bed floor.
I do believe that the puck system and the gooseneck system are both sound ways to install a fifth wheel hitch and keep the bed floor flat when unloaded.
I personally think one big hole in the bed is better than four but I digress. There is no doubt that the puck system is the most direct way to attach a fifth wheel hitch to the frame of a truck.
Thanks!
Jeremiah
