johndeerefarmer's avatar
johndeerefarmer
Explorer III
Sep 22, 2017
Andersen Ultimate Hitch and half ton truck- Not so good
I bought a '17 F150 in March. I tried to tow my GD Reflection 29rs and had all kinds of handling issues. I added Bilstein 4600's on the rear, and air bags. I then took off the air bags and installed Super Springs. I finally gave up and ordered a lighter and shorter Reflection 220rk. I got it last week and the problems persisted.
I finally borrowed a B&W Companion and all of my troubles went away. The Andersen unloads the front axle so much on a half ton that the truck just wandering all over the road and the steering was very light. With the Companion the steering feels tight like when not towing, this is because the pin is 1" in front of the rear axle and not behind it. With a heavy diesel engine and a heavy truck the front axle unloading may not be an issue but with a half ton with a light weight aluminum engine it was a major problem! I called Andersen and they knew nothing about it as they had no experience with it in a new F150. An engineer was supposed to call be back but that was 3 days ago. I am disappointed in my $800 hitch and the company.
  • You should have just kept the bigger trailer, and borrowed the ruby red 15 F350 from your wife. You could have still used the 17 150 to get the groceries!!
    Sorry...couldn't resist!:)
    Jerry
