jbeliera
Oct 13, 2017Explorer
Anderson Ultimate fifth wheel hitch
For those of you that own an Anderson fifth wheel hitch that adapts to your king pin a word of warning. Recently I purchased an Anderson hitch and on return from my last outing, I dropped my fifth wheel off for winter service with the service provided that I have used for quite a few years. I felt quite confident that when I told the service tech that this hitch needed a 2 and 5/16 inch ball to move it around because that was the size that this hitch came with, HE I thought made note of that fact. At this particular center they service various makes of rigs. They use a fork lift with a device on the forks that has a permanent generic size ball attached to the end of the forks to move the rigs around. Well to make a long story short, when I came back to get my fifth wheel I noticed that the red plastic shroud that is attached to the adapter block of the Anderson king pin adapter was cracked. Luckily the hitch people who installed this hitch for me were right across the street from this service center. The hitch rep said that not to let anyone move an Anderson hitch fitted trailer without using the same size and length ball as the Anderson set up or damage to the adapter can occur. The aluminum slide pin hole was also damaged while being moved by the RV service dealer. The hitch service tech managed to clean up the pin hole so the locking pin would lock onto the Anderson ball in the truck. The hitch tech also said that mine was the second one this week that someone did the same thing moving the fifth wheel without the proper size ball. The Anderson adapter block is made of aluminum and the hard steel ball on the fork lift fits sloppily in the adapter socket and can break the plastic shroud,mar the aluminum socket as well as the slide pin hole. The RV service dealer learned a valuable lesson that day and they agreed to pony up the cost of a new plastic shroud and the hitch retail provider's labor cost to bring the adapter back up to speed just like new. Anderson Hitch Owners Beware
