richardcoxid
Mar 18, 2017Explorer II
Anderson Ultimate vs Pullrite Superlite
I will probably be purchasing a new Short bed Extended Cab TV in the next few months and am also looking into new 5th wheel hitches.
At present the Anderson Ultimate and the PullRite SuperLite (Trailer Life, Nov, 2016 article) hitches have caught my interest. In monitoring this as well as other RV blogs, other than early production issues, almost all owners are happy with either one. One of the differences that I can see is that between the 2 brands they have reversed the positions of the "Ball" and "Funnel Shaped Cup". I.e. On the Andersen the ball is in the TV bed with the "cup" and latching device mounted upside down on the pin box and the PullRite is just the opposite, the "Ball" is mounted upside down on the pin box, and the "Cup" is mounted in the TV bed.
Is there any clear cut advantage to either way?
In my mind the Anderson overall looks to be something that was clobbered up by a engineer and a welder to prove a concept, while the SuperLite looks more "professional " and has a "finished" product look. Probably only Cosmetic!
When hitching up/disconnecting a extended cab short bed truck can you see over the back seat and see either hitch base in the rear view mirror? If not, what tricks have discovered to assist you in lining up the ball and cup?
One of my local dealers who sells both brands says that because of the 5 inch off set built into the base and the 4 inch off set in the coupler block in the Anderson that there isn't the the sharp turning interference problem between the cab/5W on short bed PU's as there is with the SuperLite. Anybody have any experience with this?
Thanks in advance for all your thoughts and comments!
Coxid
Coxid
