Searching_Ut
Mar 21, 2017Explorer
One difference worth thinking about should you have a newer rig that will quite probably be spending time at the dealers is the different ball adapter. With the Andersen type the dealer can use the ball on his forklift to move the trailer without you're removing the adapter. Of course on mine the dealer damaged the hitch adapter twice doing this. The ball didn't go deep enough into the socket and damaged the lip where the lock pin slides. The first time it was easy to blend out with sandpaper, the second time they replaced the adapter.
Also keep in mind that with the Andersen, and the Pullrite from what I can see, you change the effective length of the pin box, which could be a plus or a negative.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
